It is currently Thu Sep 18, 2025 1:07 pm
 Post subject: Compound Cutaway
PostPosted: Mon Jan 25, 2021 1:50 pm
I've done one compound cutaway and must admit it was not a lot of fun. I got it done but that twist in the side fought me the whole way. Now I'm thinking of doing another one for an upcoming 7 string classical. The first one I tried was on a Venetian cutaway. I'm thinking it might be easier on a Florentine cutaway because I could work on the cutaway part of the side separately from the rest of the side. I'm also hoping that I could get it glued up with less residual twisting forces going down the side than I had before. Does anyone have experience or opinions they can share in this regard?
 Post subject: Re: Compound Cutaway
PostPosted: Mon Jan 25, 2021 3:15 pm
Last Name: Kincheloe
You mean like this, where the heel tapers down to a narrow endcap and the side is twisted to form a continuous surface rather than having a corner sticking out like usual?
I haven't made one like that myself, but I always struggle to prevent twists from developing when bending sides, so I can guess how it's done :) The main thing to note is that the bend radius is tighter on the fingerboard edge than the heel cap edge. So by focusing heat and bending pressure on one edge at a time, you can tighten and loosen them to induce a twist. You'll need a little extra side width since you'll end up with a corner pointing up toward the fingerboard and a corresponding gap beside the heel cap. But don't make it too wide or it will be tougher to twist, and may partially un-twist when you trim it to width, due to cutting off the fibers that were most strongly bent.
PostPosted: Mon Jan 25, 2021 4:39 pm
This is a place where a double side really helps. The thinner material (and especially so when used with super-soft) is easier to form in the compound shape. Laminate them in a well made form and they will hold shape extremely well.
Burton
Brookline, MA.
PostPosted: Mon Jan 25, 2021 5:29 pm
excuse me if I'm being an idiot and am thinking incorrectly, but since the side adjacent to the back has a larger radius that would mean it requires more length of material to traverse the distance to the heel...and to me this would imply you would end up with the bend pointing down not up towards the fingerboard...
PostPosted: Mon Jan 25, 2021 6:48 pm
Yes, that's what I mean. The picture you posted Dennis looks like a very nicely executed example. The double side idea sounds really good. Thanks for that Burton. If I did a Florentine cutaway, I could probably get away it doing a double side only for the cutaway region. I'll have to make up a mold and give it a try.
Incidentally, some time after my client had his guitar, I asked him how many people that he showed it to noticed and commented on the compound cutaway. His answer was zero. They noticed lots of other things about the guitar but not that. So there is part of me that asks why bother. My client has just asked for a cutaway and I doubt he is even aware of compound cutaways. Trouble is, I think they are very cool.
PostPosted: Tue Jan 26, 2021 12:01 pm
State: West Somerset
Country: UK
Doesn't actually help with your issue but I avoid it. Dave
PostPosted: Tue Jan 26, 2021 1:07 pm
Ditto. So far anyway.
PostPosted: Tue Jan 26, 2021 2:16 pm
Yep, that's what I usually do.
PostPosted: Thu Jan 28, 2021 1:11 am
First name: Kenny
Last Name: Hilliard
City: Hermitage
State: Tennessee
Zip/Postal Code: 37076
Country: United States of America
I'm about to my first and this is my thinking. Seems to take away a lot of headache.
PostPosted: Thu Jan 28, 2021 11:33 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I agree it's really hard to bend guitar sides to be 100% vertical once the side is assembled. I have a slight twist in my pointed cutaway in my recent build too. So it's easy to create a compound cutaway if you shape the heel block to the right shape.
But binding installation will introduce more difficulties.
Typhoon Guitars
